Dual Rates Setting?
I have completed building a WM's Rambler 45 and I noticed that the instructions only have 1 set of specifications for the control throws. I have set-up the plane with these but I would like to set-up dual rates. This is a low wing trainer for me so I would like to have one set-up for more docile flying. Would that be 80% of the specs? 60%? Or do you typically setup dual rates the opposite way, ie. use the specs for the low rates and then setup the postiion 1 rates for 125%?
Jeff
