RCU Forums - View Single Post - Dual Rates Setting?
Old 01-04-2005 | 06:09 PM
Broken's Avatar
Broken
Default RE: Dual Rates Setting?
For your first flight start at the recommended high rate throws @ 100% (see how it handles) set low for 50% on the ailerons and 60% on the elevator. After you ring it out a bit you can add more deflection to the high rates and modify the low for comfortable flying..
Thats a safe approach....... good Luck.
