RCU Forums - View Single Post - Right thrust for engine mounts
Old 01-04-2005 | 08:54 PM
phread59
Default RE: Right thrust for engine mounts
If no reccomendations are given. Build it as suggested in the plans. You can always make a shim out of hardwood for under one side of the mount to add the right thrust later if you need it. With a Cap style plane more than likely you will not need or want any.
Mark Shuman
