What is best way to mount a tail servo in ARF ?
What is the best way to mount a servo in the tail of an ARF instead of using pushrods ?
Should I just trace and cut out the balsa where the servo will be mounted and reinforce with some ply from the inside, or should I build a little servo tray slightly bigger then the outline of servo and glue it on top of balsa (outside) at the back of the fuse, and then cover back up with some trim sheet or other covering ? This is for my YA 120 size Sukhoi by the way. Just want to make sure I beef it up enough before starting to cut out any balsa.
Any tips, suggestions on how to do this ? A picture would be nice also if available. Thanks
