RCU Forums - View Single Post - BOAT RETRIEVAL-Add your ideas on boat retrieval
Old 01-05-2005 | 03:53 AM
OPS67RCB's Avatar
OPS67RCB
Default RE: BOAT RETRIEVAL-Add your ideas on boat retrieval
The best idea is to install a Mini-JET. I have 4 1/8 scale hydros all with one in them (only because i can) i also use a smaller motor and one or two battery's,It is only to bring the boat back, so it doesn't have to go fast.The motor is turned on with the throttle servo in the full off position and full trim.I leave the reversing flap off and just have the water coming straight out and use the rudder to steer with. To install in any hull place it at the rear off the hull, (of course) and on the right hand side looking from the rear. It is only for bring back a stalled /stopped boat, if you have a blow over or crash you are not looking at what you are doing.[link=http://www.shop.graupner.de/webapp/commerce/command/ExecMacro/Graupner/macros/main.d2w/report?lang=en]Click here and search mini Jet[/link]
