RCU Forums - View Single Post - Excelleron 90
Old 01-05-2005 | 06:18 AM
  #312
Bob Pastorello's Avatar
Bob Pastorello
My Feedback: (198)
Default RE: Excelleron 90
dreadnut - my picture that you refer to was in reply to someone wanting pictures of that kind of configuration. It is what I normally use, but it is NOT what I did on the Excelleron. No need. The pre-installed plastic cable guides, and the trays, are perfect. I'm very critical of these setups, and was hesitant, but after installing it dead stock, and flying it, I'm happy I didn't try to convert to my "normal" setup. What SA has built into the design is just dandy.
Good use of those hinges!
I also concur with Eddie - you will NOT have enough vertical for very enjoyable flying, even if you're not using it for competition. It's a big fuse, bigger wing, and needs more punch.
