RCU Forums - View Single Post - 140DZ idle problems
Old 01-05-2005 | 11:11 AM
Dave Shadel
Default RE: 140DZ idle problems
Did you take the disc valve apart from the backplate? If so, when you re-assemble the parts, the clearance between the disc and the backplate face must be very tight.
After crashing, there could also be leaks in the system that you cannot easily find.
Consider having the engine serviced by our service dept.
