RCU Forums - View Single Post - Kyosho Cap 232 40 size Elevator trouble
Old 01-05-2005 | 08:07 PM
wings's Avatar
wings
Default Kyosho Cap 232 40 size Elevator trouble
Hello,
Has anyone had any trouble with the elevator set up on this ARF?
My problem is that one half travels farther than the other. The reason is because when the servo arm is nuetral it is at 90 degrees. When the arm goes forward it also moves to the right (looking down on it). This in turn is causing the entire rod assembly (wooden dowl and all) to rock to the right. When this happens it pulls one elevator farther than the other. Same affect on down elevator.
I am starting to come to the conclusion that this set up may not work. I have already glued the hinges on the elevator, so I can't easily add a rod connecting both halves like most planes.
I can make it somewhat better by bending one of the rods. But this does not totally correct the problem and I don't trust depending on a bent rod that could flex in flight.
Anyone have any suggestions?
Matt
