RCU Forums - View Single Post - Kyosho Cap 232 40 size Elevator trouble
Old 01-05-2005 | 10:36 PM
tIANci's Avatar
tIANci
Default RE: Kyosho Cap 232 40 size Elevator trouble
Dude .. teach you one simple trick ... try attaching the elevator pushrod clevise at different points on the elevator horn. E.g. lets say RIGHT side travels more than LEFT side. St what you do is to attach clevise to the outer most hole on the RIGHT horn and perhaps a little further in on the LEFT horn. This does help the situation. If you use the adjustable horns you can fine tune it more. Hope this will assist you.
