RCU Forums - View Single Post - C-130 updates
Old 01-05-2005 | 11:58 PM
  #731
A4HawkPilot
Default RE: 130 Flaps
Wow, it finally came!
I got the landing gear box built and installed as well as the nose wheel bulkhead and nose wheel steering assembly. I pretty much have a rolling airframe now I just have to get one more tire for the front. I also have the stab sheeted with servo holes and elevators cut out. Tomorrow if the bad weather holds out and keeps me on the ground then I will finish the rudder and start on the WING [:'(]. I want to fiberglass everything at the same time so I will wait until after I finish the wing. I think I'll go with 3/4oz cloth.
Anyway, my question is did you guys fiberglass the wing first and then glue the nacelles on or glue them on and then glass the wing?
Also, have you tried or thought about concealing the rudder linkage in the fuse? I'm not sure if there would be enough room. If I was going to do it I guess I would use music wire with an arm soldered onto the bottom unless there is an easier way of doing it.
