RE: Cmpro Christen Eagle
Well... 12 lbs is not that light... It certainly didn't feel that heavy next to the CMP Yak54, which I kept. But if you're not planning to do any 3D, then a 120 should still be good. The YS 110 will be definitely enough to give the CEII a good vertical. If you're looking at the GSP webpage, it's not correct. The CEII has a built up wood fuse not fiberglass. There use to be a 63" CEII, maybe that's what they are referring to. In any case, 110 is definitely good to go... keep me posted and please please take pictures!!!
