RCU Forums - View Single Post - CG for Speedy Bee
Old 01-06-2005 | 11:32 AM
bbbair
Default RE: CG for Speedy Bee
OK Mars;
It sounds like you have done some serious Mods to the Bee - Good Stuff!
BUT... (there's always a but) you didn't mention the Horizontal Stab, this item is designed as a 1/8" piece of Balsa. I had TWO of these break in flight, my recommendation to you is to reenforce the H Stab.
I would suggest that you build a H Stab with the Leading Edge made of Plywood or Spruce (just the first 1/2") that will stiffen the H Stab without adding too much weight.
Good Luck and let me know how it all works out!
