Mixing up ailerons will give you spoilers, which will cut the lift of the wing. I've heard of some people using flapperons (Up elevator + down ailerons) used for Harriers, and up elevator and up ailerons for Elevator manuvers.
Check your advance menu and see if you have airbrake setting. I use the 8UAF so I am not sure about the 7 series.
Kevin
