RE: Something leaking off of my flywheel NTC3plus
You might try pulling the whole clutch assembly (including the flywheel) off, and checking the bearing on the engine block to see if that's the source. Could also be coming from the carb. If you can't find the problem, try sealing up the engine real good and see if that takes care of it. I know i'm stating the obvious, but it's it's probably just a leak somewhere. Could even be coming from your fuel tubing.
But i gotta tell you, i never seen a goldish liquid before. You sure it wasn't on the carpet before?
