RCU Forums - View Single Post - Question about Taildraggers
Old 01-07-2005 | 03:55 PM
jdewolftx
My Feedback: (14)
Default Question about Taildraggers
I need a little help with my taildragger. This is my first taildragger. It is a WM Rambler 45 and I have the CG setup about a 1/4 of an inch in front of the recommended CG point (this is without fuel). With Fuel, I assume that the CG moves even farther toward the nose. I am still breaking in the motor and have been trying to taxi on the grass at my local field but it noses over very easily (as in all the time).
What are the things that I can check on? I know that you should use full up elevator when taxing around but it still has a tendency to tip.
Jeff
