RCU Forums - View Single Post - Question about Taildraggers
Old 01-07-2005 | 04:39 PM
jdewolftx
My Feedback: (14)
Default RE: Question about Taildraggers
Thanks for the size recommendation. The only potential problem I see is that when I switched from the foam to the rubber wheels, the width of the wheel increased slightly. It was enough that my wheel collar is basically at the very end of the wire shaft. Is this a common problem? Are there any workarounds to "extend" the shaft area or to fix the wheel to the gear?
