RE: Excelleron 90
I hit the first snag. I bolt the wing on and check tip to tail, and all is well until I sight it from the rear. The wing is *banked* about 2 or 3 degrees to the left. I can tweek the horiz stab to the left so its paralell, but then the vertical is wacked.
The thing to do, I suppose, is to trim the left wing saddle. Then I would have to *move* the left side dowel hole up somehow. [:@]
Has anyone else had this problem, and how did you fix it?
