RCU Forums - View Single Post - Engine mounting help
Old 01-08-2005 | 09:32 AM
NJ Flyer 72's Avatar
NJ Flyer 72
Default Engine mounting help
Hello, I'm in the process of putting together a GWS Win Wind, and need some advise on installing the engine (all my other arf's had the holes pre-drilled). The engine mounts were already installed and the recommended engine (OS 40 LA) fits perfectly.
I am going to use screws and nylon lock nuts... but my main question is--> When drilling the holes, do I make the holes big enough for the screws to slide through or do I want to have to make some resistance for the screw to go through the engine mount ?
Also, can someone recommend the proper size screws, nuts, drill bit etc... ?
Thanks, NJF72
ID:	212146   Click image for larger version
