RE: ct4s bad steering
because cen vehicles are based on the fun factor platform they share many common parts.... One of these common parts unfortunately is the steering servo and the radio/tx combo...... the servo should be replaced with a high torque servo... I used hi-tech hs645mg.... around 130 oz torque compared to probably 50 for stock..... The car will turn tighter than you can imagine....
Also, replace the radio/rx system... it will eventually die on you..... It may also be part of the problem....any 2-3 channel will work fine.. go with fm... less problems.. Don't buy a package system with cheap servo's.... you won't solve your problem... The hi-tech servo only costs around $40-50 dollars...
