I was working on the box until 2:30am this morning and went back at it around 9:30.... installed a small fan in the bottom to vent any flammable gasses from the bottom and help keep the charger cool. I installed a tamiya connector on the fuel pump so I can completely detatch the lower tray if I need to, installed all the hot wiring. I need to get some angle aluminum I have at work to make little stops to keep the battery in place, and I also need some sort of fittings to mount to the side of the box for the fuel entry/exit. I have both a hobbico and a dubro fuel cap set but I didn't realize the "return" portion of those sets arn't like the supply with a fitting on each side of the nut, so I need to source some other fittings to finish that up.
here are some more pics:
http://img.photobucket.com/albums/v4.../fieldbox7.jpg
http://img.photobucket.com/albums/v4.../fieldbox8.jpg
