Difference in rule change forms, which is correct?
I have found that the current rule form posted on the AMA site as #333 PDF rule change is different than the one that was adopted in the the new documents contained in the new contest board procedure's. The difference is the current posted #333 requires only three current open members to sign the proposal and the form in the new contest board procedure's requires two open members and one contest director. I have emailed Steve Kaluf but with the weather causing the power outages in Muncie, and headquarters being closed, I have heard nothing back. Does anyone have any insight as to which for is correct? I hate to just assume ( you know what that stands for) its the new one in the contest board procedure's but if I had a choice I would probably select it.
Marty King
AMA 39945
NSRCA 2551 D-4
