RE: DOES AMA COVER ...... ?
Right. There is NO requirement set in the Safety Code that specifies anything about the flying field and that is the only exclusionary document. If it is followed, you are covered. However, as another pointed out if there is a local rule prohibiting the activity you are probably not covered as you would be operating outside the Safety Code.
