4 Play. I have a question for you. I am doing primer on my hull and cabin right now. Used epoxy glass for the deck and will plank deck the fishing deck with a product I found at micro mark using 3/16 decking. Be sure to check it out. It comes with the caulking already in place.
Did you use the dowels for the tuna tower or did you construct them out of tubing?
One thing to pass along on the construction to any future builders. When putting the wedges along the sides, be absolutely sure that you don't install them with any pressure as it will widen the hull and put it out of fair. It will also push the inner sides together making your cabin structure almost impossible to install. This is step #13 on the instruction sheet. If you don't heed thisyou will be doing a lot of this[:@][:@][>:][
