RCU Forums - View Single Post - XCELL ST vibration
Old 09-01-2002 | 11:29 PM
DavidH
Default XCELL ST vibration
IF the blade axle is bent the blades would not stay in track. You could track them and have them in track , but soon as you pumped the collective couple of times they would be out of track again .
They would be continously going in and out of track if the blade axle is bent.
How did you determine the replacement axle was bent?
Also usually a bent blade axle does not cause the vibration your describing except when the blades are out of track.
Just trying to help.
David
