RE: Building a DraganFlyer - need to mix speedcontrollers - HELP
[sm=confused.gif]
i have yet to try a loop or roll on this DF, but if i can get a saftey net it's going to happen sooner or later...
also, in order to use the cat and duck method on the draganflyer, it would require a lot of power to be able to carry a cat/duck payload let alone the fact that it would end up top heavy and the cat may stick it's nose into the props out of curiosity and you end up with a dead cat and a topheavy craft with no cat to observe your relative position to gravity with.
Cheers,
Clam
