RCU Forums - View Single Post - Dont need after run oil if you use morgans fuels?
Old 01-09-2005 | 08:38 PM
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Dont need after run oil if you use morgans fuels?
Morgans does a lot of engine testing, not just on model airplanes but also go kart engines an moter cycles, I trust their recomendation over engine manufactures. Adding petroleum after run oil does not get rid of the remaining model fuel, in fact if you have a high nitro fuel the after run oil will float on top of the fuel. It is also lighter than water. I have always thought that petroleum after run oil is sometimes a cause not a cure for corrosion. The best after run oil is plain old bean oil.
