RCU Forums - View Single Post - Engine Question!
Old 01-09-2005 | 09:01 PM
Antique's Avatar
Antique
Default RE: Engine Question!
If the case is tapped just under the exhaust the thread is most likely a 1/4-28...You can get a SHORT bolt at the hardware store, use the washer from a glow plug, and stop up the hole...[8D]
Pressure in the crankcase is no more than 5 or 6 lbs, and is intermittent...Not nearly enough to dislodge anything....
