RE: wheels not responding to remote
diconnect the servo saver & see if the servo turns to the right & left without the servo saver hooked to it.Ift the servo works properly then center you steering trim & reattach the servo saver so wheels are as close to straight as possible then try steering again.All should be well.if wheels are off slightly either use the trim or adjust the steering rods so wheels are straight.
