Thunder Tiger 1.20 Problem....Help!!
Hey Tom, I played around with the pump and High end needle considerably and found the following...The pump is close to maximum open setting...my high end needle is only open 9/10th of one turn...!!!! I was not comfortable with that at first however...I have less trouble with gurgling at low end/midrange and my transition is good to full throttle.. Have no trouble richening her up at all.... !! n At first I thought I needed to turn the pump pressure down so that I could open the high end needle more but
this seems to be the ideal setting..!!!
I would like everyone elses opinion on this..!
Thanks Alan
