ORIGINAL: rocktrob
I adjusted my lower blades so that the assy is now directly over the splined part of the shaft and it is actually getting lift now. Do I need to super glue the plastic piece to the metal splined part? Also, mine doesn't want to move forward of backward very well, moves great side to side and yaw but not forward and backward.
Welcome rocktrob. After the shaft is centered on the slotted part, tighten the screws on that little collar by popping off the u-shaped link. This lets you rock the swash back and forth to get to the screws. Then put a little glue around the top. This will keep the main rotor from sliding back up if the screws loosen.
