RCU Forums - View Single Post - Well now everythings just going wrong...
Old 01-10-2005 | 09:22 AM
Fastsky's Avatar
Fastsky
Default RE: Well now everythings just going wrong...
Hey Ice before you trash the pump, you stated that you have filters on both sides of the pump. They could be glogged! When that happens the pump slows down and barely moves. Its easy to check. Remove the filters and hook the fuel tubing directly on to the pump and see if it works then! IF it does then you know you need to clean the screens or replace the filters depending on which type you have. If the pump spins, it should be pumping. If it doesn't spin after the filters are off, then I have to assume the pump is shot. [8D][8D]
