RE: Webra 1.20 Problems
If you are not running a pipe or tunned muffler per Bob then there is a fair likelihood you are under proped. Very often enines that are under proped will go rich when they unload in the air. Try a prop with 2 inches more pitch and you should be able to tell right away. I wouldn't try an inch more diameter because there is a good chance it will unload the same way as your current prop.
Denis
