RCU Forums - View Single Post - Self Teaching - Maiden Flight
Old 01-10-2005 | 02:38 PM
britbrat
Default RE: Self Teaching - Maiden Flight
Sounds like a remarkably good first/solo flight. Amazing! You want to hold your descent rate steady all the way down to about 1 foot above ground, then GENTLY flare and try to just hold it off the ground by feeding in back pressure on the stick as needed -- eventually it will settle onto the ground.
