RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-10-2005 | 04:41 PM
  #115
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: Vectorflight Edge 540 build
ORIGINAL: ez2bgman
After a few discussions with Primodus, I may try the dowel in the former/nylon bolt idea or I may fashion one out of balsa sheeting and spruce spars.
I also considered building one out of spruce and balsa. I was thinking maybe making one much like alot of wings attach. By using two short dowls on the tail side of the pan, and maybe a nylon, or possible bolt and blind nut system on the landing gear end. I also considered making 6 little 1/2" by 1/2" squares out of 1/8" Ply with a 4-40 blind nut in each little square. Then epoxing 3 down each side, and using 4-40 bolts instead of the screws. Then I would feel comfortable just taking the pan on and off with my cordless drill. I would be afraid to use my cordless with the method I am using now, which is just screws screwed into the fuse side.
