RE: How does the Jetronics gear sequencer work ?
Gordon
be careful adjusting the sequencer to the mode you want. the adjustable pot has no stops so be sure to count the number of clicks you move from the starting point. the sticker on mine was canted just a smidge, so when I thought I was in mode #?? I was actually in the mode directly next to it and nearly got into a "do" loop trying to figure out where "neutral" was.
the electronic valves are awesome!! 3 mm lines or equivalent BVM large bore air lines work great. the 3mm bore on the lines will move a lot of air in a hurry. easily handled the gear and doors on my Hornet. work your way up from 60 psi, you'll be suprised how fast your gear will move. watch your appendages @ 100 psi.
good luck
High Flows and JMP sequencer. no fuss no brainer or Jettronic valves and JMP sequencer.
Buck
