RCU Forums - View Single Post - Turbine Enforcer
Old 01-10-2005 | 11:17 PM
cheche106
Default RE: Turbine Enforcer
Hi Joe,
This is a Balsa USA Enforcer Kit. The tank on the bottom was for extra fuel.
I don't use it any more. I modified the kit to use a larger tank inside. This motor needs fuel.
The jet weighs 16lbs, and the motor has 22lbs of thrust. I have Dave Brown Carbon fiber ribbon
on all spars, and trailling edge. She turns very tight!
I got the idea to build this kit from you Joe, as I had seen your ByroBlaster on RCU early last Year.
Chet.
ID:	213439   Click image for larger version
ID:	213440   Click image for larger version
ID:	213441   Click image for larger version
ID:	213442   Click image for larger version
