The book says " the balence point is actually a range between the main brace and 3/4 behind the main brace ",
The plane flies like its on rails ! I had a k&b 61 on it and it was really fast . The plane is really "thin" as you fly it
make sure your colors contrast . I flew mine into some power lines when we joined our new club[
After you slide the wings on just use a zip tie to hold them together , I also glued some studs into the wing so when
they slid on they would have a nut on the inside of the fuse , I use to do aileron rolls with full throw and it was a blur !
Every time I did that I thought the wing were going to come off
Not sure if Ill ever try to fix mine , not woth the
effort with the cost of arfs these days.
Hope this helps
NATHAN
