RCU Forums - View Single Post - Engine mounting
Old 01-11-2005 | 09:25 AM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Engine mounting
One of the reasons is to get the tank at the correct level. The center of the tank should be no higher than the fuel jet in the carb. On many planes, you can't get the tank high enough if the engine is mounted upright. If your tank is too low, the engine will lean out excessively during flight.
