RCU Forums - View Single Post - fuelproofing
Thread: fuelproofing
Old 01-11-2005 | 12:42 PM
chris_in_montreal's Avatar
chris_in_montreal
Default RE: fuelproofing
Hi samsdad, i'd recommend fuelproofing the entire compartment where the fuel tank is located with epoxy watered down with a little denatured or rubbing alcohol (turns the epoxy watery and makes it easier to paint on). Although no fuel may get in from the engine exhaust or through the firewall if your fuel tank ever leaks you'll be glad you did it.
