RE: G2 multiplayer
If you're wondering what on earth could be so complicated about a server.... so are we.
My co-worker posted this on another forum. It pertains more for the update/registration process than the multiplayer listing service, but I'm told that they are all suffering because of the same problems:
"Hello all. I apologize for the lack of info here. I've been too busy trying to help our publisher fix these problems to actually come visit the forums, and until this past weekend the fallback to the secondary server was working.... Unfortunately, it's taking much longer than anticipated to help them work through these problems. As of this posting, though, the secondary server fallback is working again... We're doing everything we can at this point. Believe me, if it were as simple as making the secondary server the primary server, it would have happened already... We did have some separate server issues that affected it last week, along with these discussion forums and some other things (why does everything go wrong all at once?), but those are resolved... All I can do at this point is apologize for the all the inconveience and do everything in my power to help fix the problem, which is exactly what I'm doing. Appearances to the contrary, we're not ignoring this issue just because G3 is out."
I can vouch for his credibility. He has been a very busy guy ever since these server issues started popping up and, knowing him, he will not stop working until all the problems are solved. When will that be? I wish I knew. The fact is, no one knows enough about the probem to make an estimate at this point. I will post here again once everything is worked out, or sooner if there are any questions. Hang in there!
