RCU Forums - View Single Post - Thunder Tiger pro .46
Old 01-11-2005 | 03:22 PM
tIANci's Avatar
tIANci
Default RE: Thunder Tiger pro .46
Don ... the low speed needle has to be tuned, it will be different due to fuel, nitro, weather etc. Just use what Gene says as a base setting, I do that with my car engines then fine tune it to suit. If the transition is such that the engine cuts abruptly then its too LEAN and if it gurgles a bit before picking up then its too RICH. I am sure you know that ...
