RE: GMS Engine Tuning Problem
Thanks Spicoli! I realized that after reading the article. Not sure if that will help this engine or not, as I can shut this engine down easily. Did you put the rtv in, in the carb area, or the bearing area. If it was the bearing area, did you heat the casting to get the bearing out?
Andy
