Hi samp615... Well pretty much just stick the bad boy on there and get to
flying
You could move some what forward/back to assist in the CG of
your plane and or connections to the engine, based on all the components
being on the plane and the tank mt. to see the best location.. Depending..
It's good also to give the engine some right thrust, some times down
also.. But your models manual should say if its needed and sometimes it's
built into the firewall.. Hope this helps...
