RE: Which Cub Builds Easiest ??
khodges,
You are correct, I was not bashing (no pun intended) on the Sig kit. In fact I have to agree with you that the Sig would be the better of the kits to build if you want the extras and scale affects. Keep the wood frames after you punch out the parts or make paper templates before you get her all together, no matter how experienced you are, you are going to have a bad day with a Cub sooner or later. In my case it was sooner (a couple times over). On a side note, for the covering I found that Worldtex fabric is just about perfect as any iron on fabric covering could be. Not only does it look the most authentic (21st is too shinny or plastic looking don't like it). But that stuff made me look like an expert at covering. I haven't done the fabric and dope treatment, that stuff seems way too heavy. Not that a Cub can't handle weight.
Mike
