RCU Forums - View Single Post - Avistar conversion
Old 01-11-2005 | 09:25 PM
  #34
StephenT
Default RE: Avistar conversion
Log
I use the Endoplasma in mine. I like being able to show off my big BRUSHED plane at the FF. I would suggest that you use a JETI 30-3 eitherDD 8-10 cells w/GP3300 or GB 2:1 on 10-12 cells GP3300. The brushless setup is less $ in the long run. There are no brushes to change out. You can use a $12.99 GP GB but the included pinion won't fit. You need a 5mm 16 tooth gear which cost $12.00 from MEC Plus shipping. DD will get you 8 minutes and GB will get you 10-12 minutes.
