RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-12-2005 | 12:06 AM
  #142
ez2bgman's Avatar
ez2bgman
Default RE: Vectorflight Edge 540 build
Here's another update.
I cut out the CA hinges in the wings/ailerons and replaced them with Robart Hinge Points. I used 5 Hinge Points per wing. It may be a bit overkill, but with the power of the Saito 120 up front, I would rather be safe than sorry.
rcfury, at first I did just the nylon bolt into the root ribs. I wasn't sure if the ribs could handle any stress back there so that is why I used the nylon bolts-in-the-dowel design. Let us know how well the bolts into the root ribs alone hold up.
Gotta get some sleep. Later guys.
