RCU Forums - View Single Post - Sig Four Star 60 cowl from scratch w/ inverted Saito 100
Old 01-12-2005 | 01:20 AM
mstroh3961's Avatar
mstroh3961
Default RE: Sig Four Star 60 cowl from scratch w/ inverted Saito 100
ORIGINAL: Swager
Nice job! Gave me some ideas!
It seems like the heads of the 4 Stroke stick out enough for cooling.
When building a cowl like this, is cooling something to be taken into consideration?
IM running a 2 stroke so mounting it inverted is not really an option (I heard they dont run well that way).
Cooling is always an issue! a small inlet at the bottom of the cowl, under the spinner, that will allow air to flow over the cylinder would be a big help.
And 2 stroke engines will run at any attitude, as long as the tank is positioned corectly.
