RCU Forums - View Single Post - engine placement
Old 01-12-2005 | 01:08 PM
-pkh-'s Avatar
-pkh-
Default RE: engine placement
If you have a plane with a cowl, make sure you get the engine positioned right for the cowl opening in front... If you can adjust the cowl mounting forward and back, then this is probably not a problem, otherwise you need to be sure you can get a prop on there without rubbing on the cowl...
