RCU Forums - View Single Post - Park flyer setup advice
Old 01-12-2005 | 01:31 PM
wildbill13
Default RE: Park flyer setup advice
Ha! Yea, I know. You see, I like to keep busy. I am into trucks too. I'm thinking of the ICE simply because it has better display, everything else seems identical to the Triton for my purposes. Can you run these chargers off a field battery? That's my plan anyway. As for the glow...the foot of snow and 3 days of freezing drizzle has put a damper on things. I'm fascinated with these slow sticks, so I figure I'll give it a whirl until the weather clears up. I have more confidence in learning to fly a couple piece of foam on a stick for some reason
This Li Poly thing has really got me baffled. I'm not sure what the current draw of a 370 motor is (10A maybe?), the rx documentation shows a 7mA draw for that. The Wattage kit requires a 10A ESC, and the ICS-300 shows Con/Max of 8/15 A, so I think that's a good match. It seems that an 8C 1500mAh would work just based on the average ratings I've been seeing as I surf around...I just need to fit it in the fuselage.
I don't know what 3S means, from tIANci's post. Does that mean 3 cell(11.1v) vs. the 7.4v 2-cell I'm looking for?
