RCU Forums - View Single Post - leaking at crankcase,front bearing
Old 01-12-2005 | 03:06 PM
madmark
Default leaking at crankcase,front bearing
looking for some info on whether or not i should be loosing fuel [only when running].its only a very small bit but i dont think it always did that ,if u go to cen site you,ll find an exploded view of nt-16 its loosing fuel around parts 20 , 17 , 09-crank case. is this cured by replacing the front bearing bearing.
Here are the part no. of suspected area G-70337-17 , G-70337-20, G-70343-09.
have alook and see does that make sense, thats where the fuel is leaking from,
hopefully not to bad , a bearing is most likely the cause of this
regard madmark
